So I have been restoring my 1066. I replaced the low pressure line for the ac and when I did the wire to engage the compressor clutch became disconnected. Where does this plug into? I can not tell from the wiring diagram. Also 3 years ago I had to replace the AC relay so the condensor fans would kick on. Now the fans wont kick on, but if I unplug the relay, bend a piece of wire and and jump the wires that would go to the relay they kick on. Does this mean the relay is bad? And has anyone ever used one of these?
http://www.apairinc.com/detail.asp?part=550-325
My 1066 has what I think they call the delux cab red with white roof condensor in back. Sorry for so many questions.
Thanks,
RH
Thanks,
RH
