F-12 Clutch peg
Tom Fleming
06-08-2011 02:41:47
Does anyone know if the peg that the clutch peddle mounts on is threaded into the frame rail, or is it a press fit? Welded? I am guessing it is threaded in, but don't have it cleaned up enough to tell yet..... .thought I would ask.
Mine is worn badley, and was looking to remove it and build up with weld, and turn back down..... I guess a bushing is also an option.
Tom Fleming
06-08-2011 17:11:07
 Re: F-12 Clutch peg in reply to Tom Fleming, 06-08-2011 02:41:47
thanks guys. This is the tractor I am taking to shows this year, last year, it was the F-20. so, I am working to get it up to snuff.
Appreciate all the feedback.
Pete in Holland, MI
06-08-2011 08:20:09
On my W-30, I laid a couple beads of weld on the worn spots and ground/filed/sanded them smooth & true. Bushed the hole in the pedal too.
Worked fine.
Dave Allgire
06-08-2011 04:16:37
That "peg" is press fit into the side rail. I found a local shop that had a 50 ton press. They pushed out the old one and installed the new one. On one of mine they had to apply a little heat. Pins are available from Rice Equipment.
oldiron29
06-08-2011 03:18:43
Tom, Not sure I never replaced one. oldiron29
