Oil level on F-20 transmission case
Mark Poss
C an anyone tell me where the check plug / oil level plug is located for the trans case on an F-20? And about how much it holds, Thanks Mark.
the check plug is on the front of the trans case between the right frame rail and the trans input shaft you should see a plug there with about a 1/2 or 9/16 square head unless someone has put a different one in at some time.
