1952 farmall super a
i got new ones just recently for mine at standerd bearing. thay didnt have the felt so i put two in wich made up the same thickness as the origenal.
There is a felt seal AND a seal with a rubber lip.(The seal with a rubber lip is peculiar in the sense that the seal is mounted on the shaft and the lip faces outward. The lip rides on a wear ring (sort of sleeve) which is pressed into the hub of the wheel.)
I got mine from Carter and Gruenewald.
HTH, Hendrik
