450 water pump ' ? '
Andrew Z
Im replacing the water pump flange pulley on 450, is there a need to break the pump in half like on the H-350 pumps or can the flange spin off the front of the pump without removal of the pump from tractor?
thanks
Andrew
The flange comes off the front, but you need to take the large nut off, then the plate with seal off first. Not much nut protruding and can be difficult to get a wrench on though.
