changing H engine from distillate to gas
amnion
03-20-2011 13:13:18
I want to change the engine on my H from the current distillate model to an actual H gas engine. I know, at a minimum, that I will need the gas engine head. Other than the gas head, what other parts need to be swapped? Valves? Rocker assembly? Etc.
Also, is the "fire crater" piston set a good option here?
farmallboy15
03-20-2011 19:31:27
 Re: changing H engine from distillate to gas in reply to amnion, 03-20-2011 13:13:18
pour gas in the tank and you're good to go. my all-fuel h runs great on gas. original head and everything.
Zachary Hoyt
03-20-2011 17:43:58
I have a gas head on the photo ads that I can ship if you're interested.
Zach
sflem849
03-20-2011 17:07:48
So true, I would be happy to just have one that is just resembles a dist manifold. Same thing for the starting tank. I don't need on in perfect condition. Something good enough I can have a fuel cap through the hood and a fuel line out the bottom.
Yooper Farmall
03-31-2011 10:44:15
 Re: changing H engine from distillate to gas in reply to sflem849, 03-20-2011 17:07:48
Did you ever find a starting tank? I have on with a hole in it but would fill the blank space in your hood.
sflem849
03-31-2011 12:07:53
 Re: changing H engine from distillate to gas in reply to Yooper Farmall, 03-31-2011 10:44:15
Me? No, I didn't find one. I haven't really been looking either. It is just one of those "if I see it" projects. Send me an email if you would like.
Yooper Farmall
03-31-2011 12:18:43
 Re: changing H engine from distillate to gas in reply to sflem849, 03-31-2011 12:07:53
I don't see your email listed but you can contact me. I bought a tank on ebay with a hole in it, then found another that seems to be ok so I have an extra. Do an ebay search for Farmall tank. If you don't find what you need at good price I have this extra with a hole in it I don't need.
pete 23
03-20-2011 16:01:26
Lots of distillate heads on old H tractors. Thing is when we overhauled them we put in a high altitude piston, like 8000' and that brought it up very close to an H with std pistons and gasoline head as far as compression ratio and horse power. The heads didn't have hard seats so valve life was not as good, but then again we put them in sometimes also and valve rotators on exhaust valves. Manifolds were usually shot anyway so had a gas one put on most of them.
sflem849
03-20-2011 14:42:16
The distallate tractors had a different manifold and also had starting tanks and radiator shutters. If you are ditching any of those distillate parts I would be interested in them.
amnion
03-20-2011 17:29:59
 Re: changing H engine from distillate to gas in reply to sflem849, 03-20-2011 14:42:16
Sorry, those parts are long gone on this tractor. The manifold is still the distillate one but it's shot and getting replaced.
sflem849
03-20-2011 17:59:02
 Re: changing H engine from distillate to gas in reply to amnion, 03-20-2011 17:29:59
Mine, too. Gotta keep asking or you will never find them. I have the manifold, but it is really in bad shape.
Janicholson
03-20-2011 13:30:58
As Tyler indicates it is OK as is.
If you want it to be as efficient as possible (HP/Hrs/Gal. of fuel) swapping the head for a Gasoline head (H, SH, 300, 350,) and putting sh sized pistons/sleeves, and domed pistons in it will make a great tractor out of a very good one. A 350 cam and intake/carb would wake it up even more. Be careful to match the piston pin size with what you have so as to not be dramatically disappointed in a batch of parts. Jim
Tyler Jackson
03-20-2011 13:19:33
You don't have to do anything if you just want to run it on gas. My H has never been run on distilate and it's made to like yours. Ever since it was new it was run on stright gas, or so I've been told. It does get better gas mileage with a regular gas head though. If you want to do that you can keep everything except just change the head I believe. I'm sure someone else can say some specifics.
amnion
03-20-2011 13:27:58
 Re: changing H engine from distillate to gas in reply to Tyler Jackson, 03-20-2011 13:19:33
I currently run it with gas, but it needs a rebuild anyway and the H gas engine gives several more HP; which is a big percentage when your talking 20-30 total.
Janicholson
03-20-2011 13:49:13
 Re: changing H engine from distillate to gas in reply to amnion, 03-20-2011 13:27:58
Do it. This site has fine rebuild kits and prompt service. You will need a head, salvage yards should have many. Get a complete head, the distillate valves are different. Rockers and such should be the same. check out caseih.com for parts diagrams. put Farmall in the model box. Jim
amnion
03-20-2011 13:58:27
 Re: changing H engine from distillate to gas in reply to Janicholson, 03-20-2011 13:49:13
Thanks Jim.
MJ in the UK
03-21-2011 05:17:55
 Re: changing H engine from distillate to gas in reply to amnion, 03-20-2011 13:58:27
My 1945 H is a distelate fuel type and all i do with the tractor is road runs. T his last year i ran it on gas and itwas perfect. The best improvement was just ticking over in top gear instead of running it in fourth with revs on. I did a 36 mile run last year wich took 6 hrs with the off road parts. When I set off I had 6 inches of fuel in the tank and when I had done the 36 miles I still had 4 inches of fuel left. MJ
