400 farmall torque
Anonymous-0
my 400 farmall has noise when torque is in high and clutch is pushed in for a l;ittle while then it quits i took top cover off of torque looks to me like it is like a throw out bearing in the torque making noise Does anyone know if this can be changed with out removing the whole torque maybe by splitting where the main clutch is at any help appreciated first time dealing with torque thanks
Could be about anything. The t/a clutch is well known to have the end of the levers burn completley off if they haven"t ever been replaced. You need to get in there and find out what it is.
(quoted from post at 00:20:10 03/20/11) my 400 farmall has noise when torque is in high and clutch is pushed in for a l;ittle while then it quits i took top cover off of torque looks to me like it is like a throw out bearing in the torque making noise Does anyone know if this can be changed with out removing the whole torque maybe by splitting where the main clutch is at any help appreciated first time dealing with torque thanks
The TA clutch can be replaced from the top after splitting at the main clutch .
