200 fast hitch - does tilt bar store on tractor somewhere ?
couv
On my 2-- with FH, I can lock the hitch into level position or float with a strap & pin.
If you do this, does the bar to connect to front TC arm "store" firmly on the tractor somehow ?
(quoted from post at 12:37:35 03/13/11) On my 2-- with FH, I can lock the hitch into level position or float with a strap & pin.
No where to firmly store it. I usually just let it rest on top of the rear axle. Other than that, you gotta remove it.
(quoted from post at 11:37:35 03/13/11) If you do this, does the bar to connect to front TC arm "store" firmly on the tractor somehow ?
Should be the same as our Super C was and we took it off when not using it, like disking, so it could "float", or planting or cultivating when the TC was being used for the front.
Better to remove it and leave it in the shed. That was the intent with the originals. You only need the long bar when plowing. It is not needed for any other operation that I know of.
(quoted from post at 21:54:12 03/13/11) Better to remove it and leave it in the shed. That was the intent with the originals. You only need the long bar when plowing. It is not needed for any other operation that I know of.
I know it`s not needed for the grader blade, but it is nice for slight tilting of the blade.
[quote="couv; I like the looks of that series and would like if you or Mark Peters up der in da nort' of Wisc. could post a photo of this. mange takk
