424 Lift Will Not Go Down!!!
TDK
Replaced all o-rings in system. Now lift goes up as soon as tractor is started. Will not go down, even after shutting tractor off.Lift control has no effect. Need suggestions, tired of fooling with it.Divider valve is in correct position. Thanks!
There's a whole Blue Ribbon IH Service Manual devoted to that lift.
If you are going to fix it, you're gonna need one!
There's one on ebay right now... auction number 380321179936, at only $9.99. (No, it's NOT mine.)
<img src = "http://www.agriconmanuals.com/images/ih4603.JPG">
