I use Autolite 3077, very good if yours likes to foul plugs. 3076 is the normal Autolite plug for this application, the 3077 has a different style tip and I have had very good luck with them not fouling.
I use those Autolite 3077 in all my older IHC Tractors. They seem to work well. I order them thru my local Advance Auto Parts store, under $3 each.
yes, in the champion line you need the W series not the D series plugs. must be in too much of a hurry to bash champion and didnt stop and think these old tractors use the big plugs.
oops , talking about in a hurry got my #'s messed up.i believe those 3077 are used in the old WD40 gas start diesel that takes a long reach. yes i know 7/8" is the W series.
Hi Big Money,
Unless your into keeping every single thing on your tractor original, I personally recommend getting some adapters and go to the new style auto plugs. You would have alot more options. there about 5 bucks a piece for the adapters.
Charles
