B farmall steering adjustment
C. Meyer
02-11-2011 16:43:17
Adjusting the wobble out of steering
C Meyer
02-12-2011 14:15:10
 Re: B farmall steering adjustment in reply to C. Meyer, 02-11-2011 16:43:17
Thank-you, this helps
gene bender
02-11-2011 19:22:15
Bearing in the input shaft can be worn also letting the worm work end-ways before making contac. You probably need a new seal in the out-put of the sector and new 90wt grease. Ive done a bunch of them.
Iowa Jim
02-11-2011 17:44:54
Check the u-joint in the steering shaft. We had a wobble in ours and found that the u-joint was needed replacement.
Jim
