I've been stuck, but never this bad
Darwindo
01-20-2011 13:31:37
third party image
I ran across this picture in a power point about people screwing things up. I have gotten stuck before, but I never did anything like this.
How would you get this thing out?
karl f
01-21-2011 15:05:09
 Re: I've been stuck, but never this bad in reply to GriffNC, 01-20-2011 13:31:37
I swear I saw that same JD in person from the road within the last 15 years around Foley MN...
Karl F
This post was edited by karl f at 15:05:51 01/21/11.
The Dukester
01-21-2011 08:25:27
 Re: I've been stuck, but never this bad in reply to Darwindo, 01-20-2011 13:31:37
Whew, that John Deere is stuck, that's for sure That field must be a recovered swamp with no bottom. My Super M with a 4 row cultivator got stuck once next to an oil well site when after a big rain it sank in the mud of a filled in sludge pit. The tractor was down in the back to where the mud started running over the rear axle housings. I had to dismount the front cultivator gangs and get them out of the way then was able to "extract" the tractor with a John Deere 4020 that had a strong cherry picker/engine hoist on the 3 point lifting on the front and and my Farmall H pulling on the stuck tractor. We made a mess in that cornfield, but we got it out....
mkirsch
01-21-2011 05:12:39
At least Bobby Goodson's boys know enough to PUSH THE CLUTCH before the mud reaches the axles.
Sometimes there's no bottom and there's nothing you can do, but 95% of the time there's no reason for letting a tractor dig that big a hole.
mike van
01-21-2011 03:15:35
Swamp logger Bobby Goodson gets a machine stuck like that at least once a week.
oldtanker
01-20-2011 21:11:52
 Re: I've been stuck, but never this bad in reply to Harold H, 01-20-2011 13:31:37
While an instructor at the Armor school at Ft Know ky had a student stick a tank after he was told not to go there bad enough that I had to step up about 18" to get off of the rear deck on an M60A3.
Rick
charles todd
01-20-2011 19:56:12
Big Azz trackhoe... At least a 320.
CT
504
01-20-2011 19:29:49
Back in the 70s Dad stuck the JD 70 so bad there was two foot of mud on the TOP of the axles.(If I had done that he would have skinned me!)
michael price
01-20-2011 19:10:53
Every time Ive seen something like that they had to dig it out then drive it out of the hole.
Bud DeLong
01-20-2011 19:09:23
The picture of that crane working on rubber reminds me of two tards at Oldsmoble! They were using a rt65 Grove with a jib on rubber and there is no chart for a jib on rubber. Said tards had the boom all the way extended with jib over the front and left it that way and went to supper!! You guessed it,Tards forgor to lock the house lock and a wind came up and the boom swung over the side!!!! When they got back from supper there layed the crane on it's side with the boom partually crushing a small brick building!!!!! ! Lockly no one was hurt but the crane was junk!! Bud.
Brian Schmidt
01-20-2011 18:44:39
third party image
Pouring the floor for my shed. About the 5th truck across my hay field. It was a little wet that day. Loaded truck just dropped the driver said.
kennell
01-20-2011 17:05:34
Its green. Why would you bother digging it out? LOL Kent
Harold H
01-20-2011 16:25:51
On the railroad a few years ago, they got a trackhoe stuck worse than that. It was down where there was over one foot of mud and water in the cab. They first tried a large wrecker truck, it was near to dry ground, but it had no luck. It took about three days but with the help of another trackhoe that was brough in and itself, they managed to get it out.
Harold H,
Bud DeLong
01-20-2011 14:09:49
Sorry to say i had my HD-21P Dozer stuck worse than than!! The dozer was 35 ton but luckly i had a 40 ton excavator! Bud.
Faster346
01-20-2011 13:56:59
third party image
730 virgil
01-20-2011 13:33:56
backhoe ?
Stuart
01-20-2011 13:33:22
You would need an excavator to dig it out.
