what engine parts can i swap between a farmall H and 350?
1949H
i was just wondering if anybody knew what parts off a farmall H engine (block = C-152) can be transferred to a farmall 350 engine (block = C-175), if any?
thank you
May not be the ideal set up, but everything except the pistons and sleeves will bolt on if the matching parts are used. If you use the H connecting rods, piston pin adapter bushings will be needed. Don't know if anyone makes a 350 piston with the big piston pin like a H.
