300 u
greyfoxxca
01-08-2011 16:25:40
third party image
third party image
just bought this little tractor. Sure had a surprise when I loaded it.
are all 300u"s this wide? My trailer fenders are 83 inches apart.
This tractor has no pto or hydraulics. Rare I suspect. A few hours of work and it is running great.
George
greyfoxxca
01-09-2011 08:42:50
 Re: 300 u in reply to greyfoxxca, 01-08-2011 16:25:40
Guys I am sorry.
The last two pics are of first the w400 with the extra length hub , the second of my w6 with the standard hub.
Next time I am at my shop I will try to see if there are numbers on the 300u hubs.
I think all posters are correct , the rear tires are not the stock size. I do believe this is not the only reason for the wide stance. The fender extenders tell me that the axle is not stock?
Also in this area there is a lot of irrigation. I believe this tractor was used mainly to pull pipe around. Everything seams to be in reasonable shape. The wide tract would be handy for the hills.
George
Dellbertt
01-09-2011 06:58:29
I believe mistakenly posted two different tractors.
The top photo of the housing/axle doesn't seem to correspond to the top rear photo of the tractor.
I saved both and enlarged them. I the ubolt shown on the top axle photo doesn't appear on the rear tractor photo.
Dell
Dellbertt
01-09-2011 06:22:00
George,
It would be helpful if there is a part number on the rim hub.
I have never seen one like it and it woud be interesting to know what it came from.
It also could be a homemade piece.
Dell
dan mcdonald
01-09-2011 04:31:07
You have a wide tread rear end. Each axle is 45" not the standard 38". Nice tractor
greyfoxxca
01-08-2011 20:41:34
third party image
third party image
well I agree with dellbertt
The wheels have the air valves on the inside so the rims are on the correct way.
If you look at the hubs coming out of the rear end they look very long. The fenders have been moved out six inches from stock.
I have a w400 with a loader the looks as if it also was widened the same way with hub extensions so the loader arm would not touch the wheel. It is about 4 inches longer on the hub than my w6 .
Old if you could snap a pic of your hub coming out of the rear end to get an idea of how long they are to the wheel that would be great.
george
D Slater
01-09-2011 06:35:28
 Re: 300 u in reply to greyfoxxca, 01-08-2011 20:41:34
I'm confused, guess the one picture is a W series rear axle housing. Looks like the other picture has the regular axle housings, but the cast wheels and rims are not regular 300U.
D Slater
01-09-2011 05:02:33
After seeing the latest picture I can see the tractor doesn't have regular wheels or axle housings. Axle housings are made like the W series tractors. The cast wheels look familiar, but can't remember where I saw them before.
old
01-08-2011 17:58:42
Looks like the front wheels are on back wards and the fenders are on extensions plus I'll bet if you look the wheel centers are also set out instead of in. I know the 300U I have sitting here is just at 6 foot wide
D Slater
01-08-2011 17:52:30
Think the wheels are just bolted in the dished out position and the rims are bolted to the wheels in the wider position. Picture doesn't look like it has spin out rims.
Dellbertt
01-08-2011 16:45:11
The rear chassis housing looks stock. I think the extra width comes from the wheel. It looks like there is an extension on the hub.
It almost looks like a dually without the inner.
Mayber there is something in the Parts Manual under options.
Someone will know.
Dell
504
01-08-2011 20:14:37
 Re: 300 u in reply to Dellbertt, 01-08-2011 16:45:11
Kinda looks like combine tire, sometimes they only fit dished out.
