int 300 utility hydraulics
john06
01-05-2011 08:33:13
I have 300 utilitiy that will not lift. I have flow but no pressure. I have replace the pump,replace filter, replace orings. I need some idea were to go next.
john06
01-14-2011 06:27:38
 Re: int 300 utility hydraulics in reply to Heat Houser, 01-05-2011 08:33:13
john06
01-11-2011 12:53:13
 Re: int 300 utility hydraulics in reply to SproutW, 01-05-2011 08:33:13
I do not have a flow contro spring .my tractor does not have power stering. If the pressure relief spring adjustment is to tight would or could this be my problem?
big fred
01-05-2011 09:14:41
 Re: int 300 utility hydraulics in reply to john06, 01-05-2011 08:33:13
I'd guess your problem is a weak or broken spring in your regulator/flow control valve.
