Water temperature gauge
RButler
New User
Where does the water temperature gauge mount on a Farmall B 1945 it has a sending unit but their was no gauge.
The heat gauge attachment, when used, (kerosene-burner and/or shutter option or above a certain serial number, IIRC), is mounted above the governor with the bracket shown here, Key # 11, part # 53620D.
If original, it would be a mechanical gauge with an attached sensing bulb, no "sender used".
<img src = "http://i53.tinypic.com/2i1kpht.jpg">
Just as Bob said but I'll add this. As your sitting on the seat it is just behind the radiator and sort of just above the steering rod. You need good eyes the be able to read it well from the seat
I just looked at my BA a tractor made from parts of both an A and 2 Bs and the temp gauge is such that I do not think it can be read from sitting on the seat because the distributor hides it
I added one to my 100, bought the bracket & gauge on line
