H throttle lever
Farmall-H
Hey guys,
I am watching this throttle lever and might just buy it. But it seems that this one is different. Is this a left handed lever or am I seeing thing wrong!?
-Thanks,
Cole
That's a common, "no name" aftermarket friction throttle for an H/M.
The hand lever rotates 360 deg around the pivot bolt. In your photo it's simply turned 180 deg away from the normal (right hand) operating position.
Incidentally I have one of those throttles on my Super H. It works great - though I replaced the stock pivot bolt/tension spring with a longer bolt and a spring salvaged from an air regulator so it looks/works more like an M&W lever.
Thank you! I was a bit confused. I am left handed but it would be very hard to get used to if it was that way!
It is upside down. There is a spring on the other side that you can adjust for the proper amount of friction. Maybe it is being displayed this way because the bolt that holds the spring is twisted off.
