farmall Dann
Went out to haul manure this morning. 350 would not turn over. Checked battery ok, checked starter ok, pulled spark plugs clyinders clean dry.Took belly cover off could not turn engine with bar. Locked!!! Pulled TA back engine would crank real slow pushed clutch down engine started and ran ok. Let out on clutch real slow TA rumbled bad engine died. Started it back up put TA foward let out on clutch real slow engine pulled way down, died! What happened! Every thing worked good yesterday!
Thanks and Happy Jesus birthday to all
