super H sterring
pblack
New User
Any suggestions on taking out the wobble on a single wheel Super H. I have removed the worm gear what next
Most likely is worn pivot shaft bushings - especially the upper bushing (it's the the one directly under the sector gear in the steering box).
If there's an radial play in the pivot shaft the bushing must be replaced.
Fortunately it's cheap and relatively straightforward to install a new bushing (been there, done that!)
