Farmall C H4 mag
Dougct
I have a H4 Mag on my C,If I switch it out with a distributor will I have to change the 3 position switch?
You can convert your mag to a distributor like in this pic. hal
The three position switch is correct with mag or not. The ignition switch will need to be changed to a pull on, push off toggle (or an original IH ignition switch) the switch will be connected to the load side of the amp gauge, and the ignition coil (or ignition ballast resistor if equipped). Jim
