2 Questions
Grumpydaniel
11-21-2010 17:00:45
1) What oil to use, since I can't find straight 30-weight, for my '43 H.
2) I have a worn shift lever, that once allowed the transmission to lock into road gear. Can this be fixed? How?
Thanks, guys.
Dellbertt
11-22-2010 09:03:54
 Re: 2 Questions in reply to Grumpydaniel, 11-21-2010 17:00:45
I use straight 30wt. in everything except the diesel. 300U's, Cub, Super A, H, JDA, Chev Caprice, Ol' Chev Pkup. Have for years without tearing down one engine. Just because I'm a simple guy and can't figure out oil with more than one number on the bottle.
The others are correct, 30 wt detergent is available everywhere including my local Sparten grocery store who sells me cases for cost.
Dell
IH fan
11-21-2010 17:41:50
 Re: 2 Questions in reply to Wardner, 11-21-2010 17:00:45
Where have you looked? Local TSC, O'Riellys, Auto Zone, Walmart, K Mart, etc. all have it around here. TSC even has it in 2 and 5 gal. containers.
Still, any good multi-weight 10-30, 10-40 or 15-40 should be okay.
Janicholson
11-21-2010 17:27:25
Same oil as your car/truck. 10-40, or 15-40 They do not need 5-wt anything, but regular quality oil is excellent.
The tip of the shifter lever (inside the trans) needs to be built up and shaped to size to fit the slots better. See archives for pictures and process. Jim
Grumpydaniel
11-21-2010 17:41:48
 Re: 2 Questions in reply to Janicholson, 11-21-2010 17:27:25
Thanks Jim, I'll check it out.
