Td-6
Greg
06-27-2000 17:57:28
Heyas,
Just wondering if anyone knows of a place to buy a 2 1/2 inch deep
socket for the crankshaft nut. There
are studs sticking out of the pulley
so you can't get a crescent wrench on the
nut.
I need to pull the crankshaft pulley
off my old engine and put it onto my
new one. The new engine is from an MD
which doesn't have the hydraulic pump
mounted in the front.
Thanks for any info,
-Greg
http://www.supercgis.com/
FM
06-28-2000 18:10:49
 Re: td-6 in reply to Greg, 06-27-2000 17:57:28
If nothing else, you can make any length socket you need by cutting one of appropriate size(only shorter) into two peices, the part that goes on the socket and the part that goes on the nut. Take a piece of pipe with an ID the same as the sockets OD and weld the socket parts to the pipe.
RB
06-27-2000 18:17:54
They make deep well sockets!Will one not work there?Go to the parts store,heck even Wally World has them.
Greg
06-27-2000 19:12:17
 Re: Re: td-6 in reply to RB, 06-27-2000 18:17:54
Hmm, maybe you misunderstood. The socket must
be 2 1/2 in diamter and 3 inches deep. It is
a really big nut and the crankshaft sticks out
beyond it by like 2 3/4 inches. I have
called around a bit and can't get one like that.
I guess I will try the Case dealer tomorrow,
I think they sell tools. Probably cost a
fortune from them though.
-Greg
twopop
06-27-2000 19:35:09
 Re: Re: Re: td-6 in reply to Greg, 06-27-2000 19:12:17
go to napa and ask for a 4 wheel drive,front spindle nut socket
RB
06-28-2000 02:41:28
 Re: Re: Re: Re: td-6 in reply to twopop, 06-27-2000 19:35:09
That ought to do it.
Les Repair
06-28-2000 19:13:51
 Re: Re: Re: Re: Re: td-6 in reply to RB, 06-28-2000 02:41:28
Save your money. A socket you want is going to cost a fortune. Use a hammer and chisel to drive it loose. Once its broken loose it'll turn easier.
