Serial numbers on M
Anonymous-0
serial number on clutch housing is 218443 X1
serial number stamped on block is 209443 X1
What year is the Tractor? 1950?
And it has a two speed PTO, has anyone heard of this on a Farmall M?
re the two speed pto. if the tractor has an aftermarket 9 speed attachment, running the 9 speed in high range will give the faster pto speed.
You have an overdrive on your tranny that will give you also two speeds on the pto. Outside of that there is no two speed pto.
