super h 1953 hydralics belly pump
Anonymous-0
hi i have a super h i just installed a freeman loader on my question is the ram feed lines they are hooked together with a tee on the left side where ther is two ports the h it came off from they had it hooked to the back port. can you tell me whtch port it should be hooked to and what is the diffrence in the ports from the left side 2 to the right side 1 the loader is hooked up to the left front now it works beter whats the diffrence ,should it have a hose hooked to each side thanks tom ih54
It will work with a a T hooked to either front out let. It would probably work better with 2 separate lines on each of the front ports. The rear port was for a time delayed lifting system. When you pull the rod, the last port on the left side will activate slightly slower than the front 2 do.
