F-14 - moving those 'hard to move' wheels
PAKEHA
10-13-2010 01:30:10
The wheels on my F-14 were set right in close to the seat and had been there for quite a number of years. To move them out we resorted to a jack as follows:
third party image
third party image
We oiled the shaft and put penetrating oil around the hub clamp. When we came round to removing the wheels a couple of weeks later to change the oil seals, they came off easily (without the need for the jack :D )
[/img]
PAKEHA
10-13-2010 13:22:12
 Re: F-14 - moving those 'hard to move' wheels in reply to PAKEHA, 10-13-2010 01:30:10
Hi Fawteen, no all my tractor is factory original as far as we can tell. It seems to have been shed stored all its life. Someone has at some point given the starting tank and hood a coat of zinc based primer, which accounts for the grey shade.
Kind regards
Adrian Whiteman
Fawteen
10-13-2010 16:19:02
 Re: F-14 - moving those 'hard to move' wheels in reply to PAKEHA, 10-13-2010 13:22:12
Wow, nice find!
Thanks for getting back to me.
John M
10-13-2010 03:17:16
When I switched the ones on my 14 from steel, I loosened the bolts and ran the "spreader" bolts on one side and it slid off fine, the other side didnt want to budge. I wanted to try something like that, but my hubs were cracked already and didnt want to make it worse. Took a week of soaking in PB to get them to finally move. Neat job!
Fawteen
10-13-2010 02:58:32
Slick.
Is that a new hood sheet and starting gas tank? If so, where'd you get the tank?
