Still cranking with photo 2
Enar
Another try with photo. Where did it go?
Enar, I rebuilt the gov. on my A last winter, and I have to do one on my Super A this winter as it won,t idle. I replaced shaft #6, lever #15, both springs -#14 & thrust #18, the rod #19 with the thrust spring, yoke #10 and pin #9 as well as the needle bearings and bushings. I got ALL the parts from my local Case/IH dealer. When I put it all back together, I set it up as per the instructions in the I&T book and the tractor now purrs, it idles great and has great throttle response. The I&T book #IH-8 is also available at your local dealer or TSC.
Hope this helps some.
