Recap: 656 Hydro sat for 6 months while fuel drained out small hole in primary filter. Replaced filter canister and have fuel at top of filters and at return line.Fires only once or twice on ether.
Have hooked 2 12 volt batteries for extra spin. Still no fuel to injectors. Is hydro so we can"t pull it. Has fuel to top of filters and top of pump.
Would plumbing a priming pump into the return line to "pump" fuel out the injector lines to the injectors work? Will the inner workings of the Stanadyne pump allow that to happen?
Any help is greatly appreciated. Thanks, Tom/Idaho
