serial numbers
wildstormkh
09-07-2010 19:37:07
looking at starting a collection and I am wondering how to verify what a tractor actually is as far as model, year, edition , (for example super or demonstrator models) Do the books only tell u the year? Thanks.
Jim Becker
09-08-2010 08:05:47
 Re: serial numbers in reply to wildstormkh, 09-07-2010 19:37:07
Just about has to be a 350 Utility.
Jeremy Hobbs
09-08-2010 07:49:33
I have a International backhoe i need to find information on. Serial number is 16900 SJ
Trans is 360553-R3
Clutch is 360486-R3 it has a C-175 motor
and a wagner front bucket
hoe has a PH60 and a 605 on its plate but no name. i need parts and need to know the model number. Can anyone help?
big_red_man
09-07-2010 21:11:37
Scotty (or anybody else), where can I buy that originality guide? I have a very early 1939 Farmall H and notice it has LOTS of differences from later ones. I wonder if anybody has documented those differences and WHEN changes were made. Thanks
Dave H (MI)
09-08-2010 07:21:23
 Re: serial numbers in reply to big_red_man, 09-07-2010 21:11:37
I was able to beat Amazon significantly on price by buying some of my books on ebay. I bought $25 books for less than $10 and picked up my Wendel book in original hardcover for less than the paperback reprint sells for today. Takes patience but i enjoy it when I get a deal.
CNKS
09-08-2010 06:02:25
Most of those differences are in the parts manual, also online at www.caseih.com. Once you get past 1940, most of the H changes are what I consider minor. Guy Fays letter series book is the best reference, still in print. He also has a hundred series book and a data book with more detailed specs for each model, it will not include serial breaks like the parts manual, though. Ken Updike (Bermuda Ken) has good publications for about the 1958-up models. The ones listed are the reliable publications -- be careful of other books and don't take them as gospel.
ScottyHOMEy
09-08-2010 03:45:52
You might try the Amazon route for the book . For the level detail you're looking for on something like your A, sometimes the Parts Catalog is your best source. By looking up an assembly, for instance, you can find the serial number break for when they started casting and machining the opening in the torque tube for the starter, or for the change from the cable operated magneto ground to the single pole switch. If you then wanted to attach a date to that you could get into the IH records on the Wisconsin Historical Society's website and find the month that the tractors with those number came off the line.
ScottyHOMEy
09-07-2010 20:18:33
It will take several references to nail a lot of things down. A good reference like Guy Fay's IH tractor data book is a good handy first reference. That breaks down a lot of the models with the usual info re years by serial number, with number breaks for significant changes (like between the Stage I and Stage II SuperH's as an example). The front of that book is a general reference section that is a gold mine for the newbie looking for clues as to just what something is, what to look for and how to interpret what they find.
Guy also put out a book with Andy Karaushaar (sp?) referred to as the Originality Guide for the Farmall letter series, which is handdy to have if that series is your interest.
Lots of online references, some more reliable than others, but it's not hard to immerse yourself in that enough to find your way around.
Forums such as this are a good place to ask about oddball finds like the vertical Delco distributors, mismatched serial numbers sometimes but not always suggesting the motor was replaced . . .
