460 utility
Willison
08-21-2010 13:52:35
Serial number is 5572 P-Y. What does the P-Y stand for? This 460 utility came from the factory without power steering, without quick hitch (2-point), without T/A, and without any hydraulics. The only thing of any use on this tractor is the pto and the drawbar. Why would they make/order a tractor with so little on it? Did the state order these just to pull mowers around? It has 14.9-28 rubber on the back, fenders, and adjustable wide front. If there was such a thing as a 460 utility standard, then this is it.
CNKS
08-21-2010 17:46:22
 Re: 460 utility in reply to Willison, 08-21-2010 13:52:35
Maybe it was a 460 wheatland originally -- but fenders and rear deck would be different. So, there was a 460 "standard" although it was not called that. I don't know if the wheatlands had an adjustble front axle, it could have been an option. The Y indicates it has a pump, so hydraulics can be added if the parts can be found. More likely a stripped version of the regular 460U as you indicated.
Al L. in Wisc.
08-21-2010 15:04:58
Your 1959 suffix letters:
P = Independent power take-off drive attachment - 540 r.p.m.
Y = Hydra-touch power supply attachment (with 12 g.p.m. pump)
Could have been a tight-wad Norwegian that took delivery of such a tractor.
king jon
08-22-2010 10:36:22
 Re: 460 utility in reply to Al L. in Wisc., 08-21-2010 15:04:58
More likely a tightwad hollander(dutchman)
Royalwapiti
10-03-2010 06:16:33
 Re: 460 utility in reply to king jon, 08-22-2010 10:36:22
I have number 4876 S-Y
It has the fasthitch, hydraulics, pto,TA, loader, whole game, and it all works..
except the PTO turns all the time...not sure how to adjust that...
Prolly ordered by a Irishman....lol
My friend has one stripped don that was used by the highway dept for mowing...
