Paul Shuler
I bought a 52 super C a few years back with fast hitch. The hydraulics always worked slow but would lift very strong. Recently while using it the hydraulics just flat out quit. No up no down no nothing. Touch control is full so it's not leaking into the crank case. I pulled the screen out and it was very clean. Talked to the old boy I bought it from and He said he had the hydraulics worked on years ago and from time to time it would quit like this and he would blow air into the fill hole with a compressor and it would start working again. I didn't think blowing air in it sounded like a good idea. I have gone through all the steps to get air out of it though with no results. The pump is warm to the touch and it sounds like it's turning when I use put a dow rod to it and listen. I'm open to any and all ideas. I need to get the sickle mower on it and knock some weeds down.
Thank you,
Paul Shuler
Thank you,
Paul Shuler
