i have a farmall m that is always hard starting, as the old starter just turns it over too slow. a couple years ago i took out the points and installed the electronic kit, and had to update it to a eight volt battery, still a slow starter. now my farmall 300 8 volt died, so i stole the one off my m. im now thinking since i have to buy a battery i might as well go 12 volt and switch the m over. question has to do with the petronix kit which is 6 volt positve, should i just switch the petronix to 12 volt or use a resistor and keep it 6 volt. also i want to sell this tractor, so the easier it starts the easier it will be to move!!
