Plane Bart
Need Help Grandpa needs his ole tractor running again.
Here is what I found IH 350
First what is the best repair manual for this tractor.
things I am sure I will need
Part numbers for points, condensor, distributor cap, spark plugs,oil filter.
how many fuel filters are there and where.
is this a 12 volt Positive ground system a wiring Diagram would be great is somone has one
DO I have the correct SE# 361552R found on right side of enggine left of firing order
I have more pictures if needed
also need to know what carb this is and a rebuild kit part number I need.
Thanks for any answers it is all appreciated.
