I want to tell everyone that helped me with the ongoing advise *THANKS TO ALL OF YOU* the M runs again.
The reason she would not fire was because I didn't pull the plugs and put the #1 piston @T.D.C. I also didn't pull the distributor and back to a position so the rotor would point to the #1 piston.
I did these things yesterday correctly and she fired right up.
I'd like to know what the ideal/normal water temperature should read on this tractor? At normal operating temperature mine reads right at or just slightly below 160 degrees.
Thanks again for your help. I appreciate it very much. gatorhide
