1) Where is a good place to purchase a good used radiator for a M/MD? Our radiator guy said our tanks were cracked & it needed a new core. I checked with Steel Wheel Ranch, only has new ones and can't ship till mid July. Emailed Weber Tractor Works, no response. I would like to get a good original instead of China made one.
2) On inspecting the rocker arm assembly for the MD, the ends of the rockers that push the valve down have pockets worn in them. No way to get an accurate feeler gauge setting like that. Could I take a small belt sander and flatten them out again or could they be welded back up and ground back down? Or would it be wiser to just look around for a better used one? Thanks in advance for any comments or suggestions.
