L terminal on voltage regulator
riverbend
I'm trying to track down the reason for my '40 H not charging and noticed that the "L" terminal on the voltage regulator does not have a wire connected to it.
What does the "L" terminal do / control ?
Thanks
Greg
Lights.
Here is a wiring diagram for the newer 3 position light switch using a voltage regulator.
Some say with the original 4 position switch and a voltage regulator nothing will be hooked to the L position.
Newer 3 position switch wiring with a voltage regulator.
<a href="http://s978.photobucket.com/albums/ae263/nemf/?action=view&current=FarmallSchematicNew3-PosSwitch.jpg" target="_blank">
FarmallSchematicNew3-PosSwitch.jpg" border="0" alt="Photobucket
</a>
I just had the same problem.If you have a Mag then you don"t need the L terminal,as long as there is a wire going from the ammeter to the switch.I"ll try to post mine before I fixed it but you"ll see that I have a short wire that feeds the switch under the dash so I don"t need the L hook up.If you have a distributor you do.
