5288 quits moving under load
Anonymous-0
Our 5288 quits moving under load. Possibly worse after oil gets up to temperature. We had it at the dealer and they replaced a couple o-rings and thought they fixed it, because they could not make it "fail" by applying the brakes. Apparently, they did experience a failure doing that earlier. I feel it is the clutch packs slipping. All you have to do when it fails is push the clutch, pick up the implement, and go again. We have used other oil besides Hytran in the rear end, could the type of oil contribute to the problem?
You don't say if sentry light comes on when it stops driving which could be an electrical problem or if it tries to move but just seems to slip. At any rate , you would need to have some pressure tests done if sentry is not coming on to see if clutch packs are pressurized along with main hydaulic clutch building pressure.
