Wood's 59A
Old Okie
04-28-2010 07:25:19
I have a 1942 farmall A with a woods 59A mower. I have mowed with this setup for 25+ years with no trouble just a few worn belts. A few years ago I broke the pullys at bottom where the belt makes 90 degree turn between PTO and mower deck. I have never got it setup right again. It throws belts & breaks belts. I have just parked it. I would like to use it. Any tip's to get setup correctly?
evilbowevil
04-30-2010 00:18:00
 Re: Wood's 59A in reply to Old Okie, 04-28-2010 07:25:19
use WOODS belts only
Ron
gene bender
04-28-2010 11:41:29
You need one with the grouve and the other is smoth so the belt doesent have to twist leaving the pto pulley they will work much better than the two grouved ones that were original.
rustyfarmall
04-28-2010 08:22:37
Old Okie said: (quoted from post at 07:25:19 04/28/10) I have a 1942 farmall A with a woods 59A mower. I have mowed with this setup for 25+ years with no trouble just a few worn belts. A few years ago I broke the pullys at bottom where the belt makes 90 degree turn between PTO and mower deck. I have never got it setup right again. It throws belts & breaks belts. I have just parked it. I would like to use it. Any tip's to get setup correctly?
Standing behind the tractor while facing it, the belt on the right side needs a 3/4 twist, and the belt on the left side needs a 1/2 twist. I went through the same thing with my 306 mounted under a Farmall H, and if the belt does not have the correct twist, it will NOT stay on. Period.
Russ from MN
04-28-2010 07:31:38
Woods has an excellent website with printable manuals that would show you the proper procedure for aligning your belt.
