Creeper gear hi/lo range troubles
texacoon
04-12-2010 05:54:45
I have a "72 Cub 154 that just had an issue yesterday for the first time with the hi/lo creeper gear.
When I stated mowing my tractor was in hi range and worked then suddenly stopped moving. I checked the stick for the hi/lo range and thought it may have slipped some way. I pulled out the stick into low and the tractor would move at creeper speed. Pushed the stick into the hi gear and it would not move at all ..
Guess something must have broke or a possible shear pin is inside the housing.. With limited experence with this setup, what will it take to fix my tractor to get it running normal agian?
Thanks
Doug
