GordoSD
I have two Stage II SH's here. Both have WFE.One is a Schwartz, the other an IH tie rods behind.
The IH wfe is much heavier r than the Schwartz.
The main Horiz tube on the IH is 4.5 " OD. The Schwartz is 4.25 OD.
But lordy, the axle/spindle diameters are 3.25 OD for the IH and 2.25 for the Schwartz.
Do I have some sort of HD IH wide front? All the mountings fit right up to the SH frame, no fabrication done.
Can someone measure their IH wide front? This one just looks too big for the tractor. Additionally it drives "uphill" with 5.50's on it.
Gordo
The IH is a beefier wide front. If the wide front was off of a MTA,400 or 450 etc the saddle in the back would be wider then the frame.
