Super A 6 volt wiring
aquanosis
New User
I'm rewiring a Super A with completely worn wiring. I have diagrams but am unsure what guage wire I'm suppose to use for the various components. i.e. wire guage between generator and regulator, for lights, to coil. Any info would be helpful. Thanks
It dont hurt if lighting and ignition wiring is a little larger then stock and if you only want to buy one roll of wire you can "get by" with 12 Gauge for lights and ignition and charging etc. 14 or even 16 could get you by for some of the lighting but like I said Id use 12 for a little overkill.
I prefer 0 better yet 00 for battery and starter and ground cables.
If I were doing it Id even consider 10 Gauge from BAT on VR or Cutout Relay up to the Ammeter and also 10 from other side of ammeter to the battery often via a wire to the starter switch. Likewise 10 from the Gennys ARM post to the VR or Cutout Relays ARM/GEN terminal. ALTHOUGH AS I MENTIONED 12 GAUGE WILL SUFFICE (if you only have one roll of wire) as typical charging currents and loads would be 20 and less amps. The stock harness may have used 14 or 16 on some lights and ignition wiring but again no harm if slightly larger wire is used.
If you use quality wire terminals and solder them then cover with heat shrink you will get a good job and connection
John T
Even if you do not use the same color code as stock, using either different colors, or tags on the ends to identify each is a good idea (for you and others) Jim
