Identifying an IH plow
IA Leo
04-01-2010 11:15:24
Believe 2-bottom trailer plow is IH, some white paint still showing. Has wheel hubs fitted for rubber tires, not cut down from steel. Has factory hyd cylinder mounts, replaceable tips, and lays. The wheel hubs appear to be old style (not roller bearing) plain bore due to length of hub. Is there any identifying construction. Is this one the sought after "Little Genius" plows? Leo in East Central Iowa
PUTTER
04-02-2010 08:14:47
 Re: Identifying an IH plow in reply to IA Leo, 04-01-2010 11:15:24
Check out the implement photos to the left of this page, you should be able to find what your looking for. PUTTER
IA Leo
04-02-2010 12:09:20
 Re: Identifying an IH plow in reply to PUTTER, 04-02-2010 08:14:47
Thanks...it appears that the plow must be a little genius two bottom but equipped for hydraulic lift which looks factory made. Was there a later model # or version of the #8? This one has steel rear wheel and rubber tired main wheels. While the lays and points were well worn and mismatched coulters, it did a nice job of plowing the garden the two times I used it. Now it is just in the way. Leo
