504 clutch update
Thanks to TractormanNC and The Tractor Vet. I just wanted to thank you and let you know the outcome. I went out to "tweek" my clutch adjustment and noticed a very important mistake I had made. I guess when I replaced the TA clutch I reinstalled the top link that connects the TA clutch to the drive clutch, I installed it backwards with the slotted side facing the wrong direction. This means when I pushed in the clutch in DD, it would not release the TA as it is designed to. It guess I was too interested in the small details to notice the large ones. Thanks again.
I had to work out many bugs on my F504 w/ TA before I got it right. Once I got it right, it only takes normal maintenance adjustments.
Good luck,
CT
