H differential removal
Zachary Hoyt
I'm almost done taking things apart. I have bull gear out, input shaft from transmission out and the brakes are off. I removed the bolts on either side of the housing, but I can't seem to convince either half to move. Do I need to take it apart to get it out, or will it come out in two halves? Thank you very much.
Zach
In addition to the 6 bolts holding the pinion gear housing on, you will see two additional holes, these holes are threaded and are put there for you to screw in bolts to pull the housing out.
You can take the whole diff out and one piece and work on it on the bench. That would probably be easier and you could see what your are doing.
