656 won't start
Anonymous-0
My neighbor ran his 656 Utility out of fuel. After he filled the tank and bled the air it wouldn't start. He changed both filters, and still nothing. Someone told him if he pulled it, it would start. I pulled it about a mile and it wouldn't even try to start. He had cracked all six injectors, but no fuel at all came out. Is there something we are missing?
The utility series is a bugger to bleed. Bleed the filter canisters, the the line to the injector pump then the injector lines at the pump the the injectors themselves. Good Luck!
Best trick I know is to crack the lines and with a blow gun and a rag wraped around it, blow air in the fuel tank. Take your time, be careful no smoking, and safety glasses would be a good idea.
