PTO on IH 1568
Appr
Does anyone have any idea about installing a dual speed pto (540 & 1000) in an IH 1568? I have been working on restoring a 1568, however it has only a 1000 rpm pto in it. All of my equipment uses a 540 rpm pto and although I don't think that I'll ever use this tractor extensively for field work; I would prefer to have both pto speeds available just in case. What would be required to install a dual speed pto in this tractor or would I be better off to forego the thought of having a pto with both speeds and leave just the 1000 rpm pto?
I'm just repeating what I remember from other threads on the same subject, but I think the dual-speed PTO unit will bolt right in. However, I think there might be an issue with the input shaft being a different size on the 1566/1568/1586 series tractors.
You have to have a coupler from a dual pto tractor and the one from your 15. Cut them in half and mate two halves of each one together. or call Bates corp, they have some made.
