184 Lo- boy fluid change
bweb
I am trying to change the fluid in my hydraulics, transmission and rear drives. I removed the male plug under the tractor on the rear housing and let it drain. However when I look in the fill holes on the rear drives there is still oil in there. How do I drain the rear drives? What did I drain? The tranny or hydraulic system? Where do they get drained and refilled? The manuals I have don't really go into much detail. Thanks, Barry
The plug you removed drains the transaxle & hydraulic system. To drain the final drives, you have to remove the final drive covers.
K-Mo
