Super M. I need to pull a Khun SR110 wheel rake which has Hyd. power up and power down double acting cylinders.
I have ordered a double acting spool valve with an open center. It is spring loaded to the center. I have put a 3/4 T in to the fill hole on the pump for the return line and extended my dip stick to check the oil level in the pump.
My first question is there are 2 outputs on the left side looking forward from the seat and 1 on the right side. Which one of these three is best to use? I have 1100Lb of pressure on all three.
The other question I have. With the Hyd lever tied back and the pump running all the time will that be a problem for the pump.
Any thoughts you guys have would be helpful. Thanks
