300 ute question
r4etired
Did the 300 utility use a flow divider for the power steering,If so where is it located. I'm trying to answer a question for a friend that is 550 miles from me and I have never seen the 300. Thanks
Yes they did. It is called a regulator,safety and flow control valve and it`s located on the right side of the hydraulic reservoir under the seat and its toward the back. It will be the inside valve if there`s two next to each other and it will have 2 hyd. lines coming out the back.
