Alan Martinson
I"ve got a "45 Farmall H and the PTO engagement lever is broken right where it meets the pto housing. I happen to have another rear end from an H so I removed the PTO from it. That PTO came out easily including the 2 foot shaft that goes into the rear housing.
I was hoping I could just replace the engagement lever. Is that possible?
It now seems easier to just replace the entire PTO. If I remove my existing PTO with the 2" shaft, can I just slide this in - or are there parts/gears to line up and will I have to remove the top cover or another cover to do that?
I think I attached pictures - but ??
Thanks.
Thanks.
