Check the valve settings in front of the steering wheel. I have one that keeps turning to half way between the single and double action setting. When they are in the "half way" position they build pressure and pull down the engine.
Flow control valve located on left side of hydraulic valve stack when sitting on tractor.There are four bolts that hold top down remove top but take care when you do,there is heavy spring in there.Orfice located under this cover.Use large flat screwdriver to remove orfice.Helpful hint use a couple of longer bolts to remove and install cover when part way there change those bolts back to the originals.Scott
